I am following this course https://www.esri.com/training/Engine/defaultui/player/modern.html?configuration=ReturnUrl%7C&prevent... on esri academy in the Data Engineering section at the last part time stamped 12:46 which is to convert the data to a spatial feature class to be able to visualize it on the map on arcgis pro i get this error.
@Anonymous User @KlaraSchmitt @BrianRollison @JustinPrather @ThomasHervey1
Can anyone help solve this issue.
@HamzaM
It looks like your question relates to ArcGIS Pro, not ArcGIS Hub. I suggest that you look through the existing questions under the ArcGIS Pro product discussion and pose your question there if you don't find an answer.
