Download option is disabled
1890
13
02-24-2020 07:50 AM
KrishV
Hi All,
I'm using Enterprise sites 10.7.1
When I click on any of the attribute, I'm getting below error instead of Chart. Also my download option is disabled. I'm using Feature Service and Shared to everyone if I have to change anything.
Even, if there are one unique value, instead of showing some graph, it shows empty chart. Is it expected behaviour.?
Please suggest.
Krish
KrishV
Hi Graham Hudgins‌,
I have tested with hosted feature service and Downloads is getting enabled but map is getting hidden as shown below:
But for feature services (Extract Capability) download is getting disabled but able to see on map and unable to download & Chart errors remain the same.
Krish
by Anonymous User
Not applicable
We should be seeing a map on hosted feature services with extract enabled (as long as there is spatial data). Can you log a support case for this? I'll need more information that they will get from you to troubleshoot this fully.
But to answer the top question - yes only hosted feature services (with export enabled) have the download option.
Nicole_Ueberschär
To summarize from my end to make sure I understand that correctly:
- in Enterprise 10.7 I won't be able to download a feature service when I'm not logged in even if it was publicly shared and published as a hosted feature service
- There is nothing I can do about the summary charts to be displayed correctly.
by Anonymous User
Not applicable
For the download issue, this is correct. You need to be a Creator to create a download item and then you must have both the extracted download data & the original item set to public for a viewer user to be able to consume the download. This only works on 10.7.1 patch 1 and 10.8+ ...otherwise you are correct you must be authenticated to generate & download data in Enterprise Sites.
There is a bug we are working on patching for the charts on private data. I'm hoping to roll this into 10.7.1 patch 2.
