download GeoJSON programmatically from Open Data site
10655
7
03-07-2023 12:42 PM
kapalczynski
I have this URL: https://geohub-vadeq.hub.arcgis.com/datasets/57759688e4944bb987add68c4f0c5ada_104/explore?location=3...
or
https://geohub-vadeq.hub.arcgis.com/datasets/57759688e4944bb987add68c4f0c5ada_104/about
I want to use python/arcpy and download all its data.  If I use the RestEndpoint there is a limit of 1000 records.  I cant seem to get all 50k.
Any ideas on how I can programmatically ?  Looking to get a GeoJSON or JSON and write it to a JSON file locally...
kapalczynski
John_Spence
Here you go...
https://github.com/wagisdev/extractservices/blob/main/extractservice.py
Just add it to your pro project and it will pull it out.
kapalczynski
OK I am a bit confused here.....
Questions:
  1. I thought I could just run the python through an IDE
  2. path_Proj - what is this for? I want to use a .bat file to run this from a scheduled task not in arcpro
  3. path_DataProcessing - what is this for?
  4. path_DataFinal - agian what is this for?
  5. I entered the portalURL below - this is NOT MINE.... its from DEQ so don't know if that is right or how to specify the actual Feature Layer.  Did I enter that correctly?
This is a public hub site and NOT mine.  Not sure where to specify where is downloading to and what format is it downloading?
# Project Store Location
path_Proj = r'C:\ProjectPath\project.aprx'
# Data Store Location
path_DataProcessing = r'C:\ProjectPath\Pull-Processing.sde'
path_DataFinal = r'C:\ProjectPath\Pull-Final.sde'
# Target Projection
targetSRID = 6597
# Send confirmation of rebuild to
email_target = '[email protected]'
email_customer = '[email protected]'
email_subjectSchema = '' #Whatever you want the subject to be here.
# Configure the e-mail server and other info here.
mail_server = 'smtprelay.gis.dev'
mail_from = 'Message<[email protected]>'
# Portal Configs
portalURL = 'https://geohub-vadeq.hub.arcgis.com/datasets/57759688e4944bb987add68c4f0c5ada_104'
portalUser = '' #Your User Name
portalPW = '' #Your Password encoded Base64.  Remove decode if you are not practicing security by obscurity.
kapalczynski
OK
I think I create an arcpro project and put the Services in there that I want extracted in it????
How do I specify where they are going and what DB?
Does the Data Store Location define this?  if so I am not following here.... how does a .sde connection files tell me what specific Features to create or write to?
Do I have to have the ArcGIS Pro project open to run this?
kapalczynski
It wont even auth and get me into their portal....
This is the Hub trying to get to:
This is the URL set up in ArcGIS Pro
https://apps.deq.virginia.gov/arcgis/rest/services/public/EDMA/MapServer/
  1. what am I supposed to use for portalURL?
  2. Its open to the public therefor NO user name or password????
kapalczynski
kapalczynski
This did the same thing by getting the data from the service and put in my SDE
Couple Hundred lines of code less.... I know I can remove a few of the Imports ... they were from a lingering script
import arcpy
import requests
import json
import os
import sys
import traceback
from datetime import date
arcpy.env.overwriteOutput = True
def copyData():
    # Set local variables
    inFeatures = 'https://apps.deq.virginia.gov/arcgis/rest/services/public/EDMA/MapServer/102'
    outLocation = r"C:\Users\xxx\Desktop\GIS_projects\TestingExportData\output.gdb"
    outFeatureClass = "TEST_PetTankFac"
    ## Add Expression
    #delimitedField = arcpy.AddFieldDelimiters(arcpy.env.workspace, "NAME")
    #expression = delimitedField + " = 'Post Office'"
    # Run FeatureClassToFeatureClass
    arcpy.conversion.FeatureClassToFeatureClass(inFeatures, outLocation, outFeatureClass)
if __name__ == '__main__':
    copyData()
John_Spence
Sorry for not getting back to you sooner. Looks like you got everything you needed.
