Detail Page
4317
07-09-2014 01:29 PM
BryanLuman
How do you set DATASET ATTRIBUTES and tooltip in detail page? I notice in the Detroit site it uses name or other logical fields for the tooltip and gives a nice summary under "DATASET ATTRIBUTES". Thank you.
by Anonymous User
Not applicable
Hi Bryan,
The Map tip should be driven off the Display Field, which is set in the Map Document before publishing your service.
The dataset attributes are part of a secondary data indexing that will populate after some time. We are working to improve the lag time, and find importance to producing this level of metadata.
Hope that helps,
Andrew
BryanLuman
So I've found that the dataset attributes do populate after a while but don't use metadata as far as I can tell. Looking at more of the Detroit examples it doesn't seem like you can control the tooltip source attribute.
by Anonymous User
Not applicable
Hi Bryan,
Hope that helps,
Andrew
BryanLuman
Thank you I'll try publishing it that way next time.
