Hi guys,
I would like to ask if it is possible to have comma decimal separator for my data in ArcGIS Hub instead of dot.
I would expect that ArcGIS Hub will take this setting from AGOL where the Language and Region is set to Czechia => comma as decimal separator.
So the data in AGOL have comma decimal separator, but when you add them to ArcGIS Hub Catalogue and look at them in ArcGIS Hub, they have dot as decimal separator (see the screenshots).
Is this the known bug?
Thanks for you help.
Jan
Hi @JanSarata thanks for raising this issue, I'll log an issue for the team to consider.
I had opened a case with Technical Support as well and they had already logged the BUG-000143763
Thanks anyway.
Jan
