Chart Tooltip
1549
09-04-2017 04:59 PM
JingjingLi
Not sure if it is a bug or I did something. But no matter how I modify the tooltip setting, the tooltip does not change.
The attached screenshot shows the tooltip.
However, my setting is as the following,
Any idea? Or anyone else experienced the same issue?
DanPatterson_Retired
It looks like it pulled the year data out as you requested... did you just try a string like "population" in for the title?
JingjingLi
Yep. Tried everything but still no luck. Even tried remove the tooltip from json but it still does the same.
KrystalPhaneuf3
I'm having this same issue.  Were you to figure it out?
