ArcGIS Tool Problem
1602
10-26-2020 05:39 PM
Arthur_Morgan
 Hello,
I think there is a bug (please correct me if I am wrong) in ArcGIS 10.8. Every time I use the Reclassify and Extract by mask tool without changing the default output path (which is the default database that ArcGIS creates in the software installation directory), the tools work fine. But each time, when I change the output path and output filename, the tools return 9999 error. Is there a way to resolve this issue?
DanPatterson
MVP Esteemed Contributor
what is the output path and filename?  If it begins with a number and the destination is a folder it will fail
... sort of retired...
Arthur_Morgan
Why does it fail if a file name starts as a number?
DanPatterson
If the output is a folder, then an esri grid will be produced.
They cannot begin with a number, contain anything other than letters, numbers and the underscore and the length can't be > 13 characters.
If you want to tempt fate further, try having a path with spaces and/or other non-alphanumeric characters in it.
The list goes on, but it is too late to look up one of the many references to "esri grid" issues .
If you want something other than an esri grid, then you have to output to something like a *.tif, by appending that file extension to it.  You might get away with breaking most of the above "rules"
Arthur_Morgan
Does that mean I can give an output to the desired folder as ~Folder_Path/10-26-20.tif?
DanPatterson
Did you try it?
or even
10_26_20.tif in case "-" isn't accepted
or
My_10_26_20.tif  in case tif's don't like beginning numbers
Just trying to narrow down issues?  Sometimes you have to experiment
