More intuitive filtered download
575
07-30-2025 07:29 AM
Status: Open
JenniferBorlick
Currently to download a subset of data based on location, the user needs to turn on the "filter as map moves" in the filtering pane and then Toggle Filters in the download view.
It is not clearly defined how to use the downloads to new or infrequent users. While I have created instructions and a gif on my Open Data Hub, it would be nice if these steps were more intuitive. I would suggest:
  • Renaming "Toggle filters" to "Download filtered data"
  • Have "Download filtered data" be on by default when a filter is triggered
  • Adding text to the download pane that says, "To download a subset of data, use the Filter Tool JenniferBorlick_3-1753885158487.png first."
Thanks.
Tags (3)
1 Comment
a_benitez
I would add that this feature does not render properly for large datasets, limiting our ability to use these datasets efficiently. As for example with the NAD: Address Points from National Address Database view | NGDA Address Theme
