Standard Prediction Error Kriging
3751
04-01-2021 03:18 PM
CamiliusAmevorku1
Hi everyone,
I have created a Geostatistical analysts layer by ordinary kriging. In order to obtain the associated uncertainty, I exported the GA layer to prediction standard error.
I wanted to ask how can I use the prediction standard error pixel or raster values to quantify the uncertainty? Is it simply plus or minus the error values?
Thanks!
DanPatterson
MVP Esteemed Contributor
Just wanted to check to see if you have gone through the help topics since you didn't indicate as such
Kriging in Geostatistical Analyst—ArcGIS Pro | Documentation
... sort of retired...
CamiliusAmevorku1
Yes, I went through those materials to be able to create my models. My concern now is how to interpret the prediction standard error map and use it as uncertainty associated with the GA layers.
Thanks
DanPatterson
some is covered in other sections beyond the basic method selection
What output surface types can the interpolation models generate?—ArcGIS Pro | Documentation
which covers the basic interpretation jargon and options.  Also in an adjacent area in the help, there are other options for further analysis of results
Performing cross-validation and validation—ArcGIS Pro | Documentation
