Problems to visualize Geostatistical Analyst toolbar
2856
04-03-2014 01:44 AM
EduardoGelcer
Hello,
I have ArcGIS 10.2 and have enabled the extension for the Geostatistical Analyst and added it through Customize in the toolbar, but I can't see the Geostatistical Analyst toolbar. What should I do to enable it or to run the Geostatistical Wizard?
Eduardo
EricKrause
That's strange... Are you sure the toolbar didn't appear anywhere?  Sometimes when you add the toolbar, it becomes free-floating (not pinned to the toolbar area), and it can appear almost anywhere on the screen (you can then drag it into the toolbar area to pin it there).  I've even seen it on a completely different monitor when I use a dual monitor setup.
Try disabling the toolbar and then re-enabling it.
EduardoGelcer
Thanks Eric. Usually I have an extra monitor when I use ArcGIS but I'm travelling so I don't have it with me. Even turning off and on didn't work because the tool bar was in the extra monitor. I had to find an extra monitor to see the tool bar and put it back to right place.
Thanks a lot.
Eduardo
