How long should I let Geostatistical Analyst Wizard run?
4209
8
03-27-2014 12:30 PM
SarahSchmeer
Good afternoon,
I'm trying to run cokriging with the Geostatistical Analyist Wizard to create a rainfall map of a large area (33,000 ha).  I'm using a point layer with 13 rain gages and a 1 m DEM that I resampled to 100 m to make the file size more manageable. The file size of the 100 m DEM is 207 KB. I started running the Wizard 24 hours ago.  Steps 1 and 2 went quickly (file selection, method selection), but on step 3 (I believe that's the actual calculation of the cokriged layer) the progress bar immediately jumped to 1/4 done and has stayed there since.  I would like to know if this length of time sounds reasonable, or if perhaps the program can't handle my DEM.  After this step I was planning on hitting the "optimize model" button, but who knows how much longer that will take...  Any feedback/experiences would be greatly appreciated so I don't prematurely abort the process.
Sarah
SteveLynch
Sarah
You have 13 rain gauges and a DEM with approx. 180x180 rows and columns, correct?
- It should have finished, you can kill the process
- what version of ArcGIS do you have?
- What operating system are you on?
- 13 is a very small number of gauges! (but I understand that is all you have)
- what type of kriging are you trying to perform?
- what transformation have you selected (if any)?
- does kriging without the DEM work?
- try clearing your cache, viz., close ArcMap, then delete all the files in this location
-Steve
SarahSchmeer
Hi Steve,
Thanks for getting back to me.  My DEM has 182 x 291 rows and columns. I'm running ArcMap 10.0 on a an old desktop (Don't know what info you need, so here's a bunch: Windows 7, Intel Core with 2.40 GHz, 4 GB of RAM, 64-bit OS).  Within the Geostatistical Analyst Wizard I selected the "kriging/cokriging" option, entered my rain gages for dataset 1, the DEM for dataset 2, and left the other settings on default (ordinary Kriging, output type = prediction, no transformation, no order of trend removal.  Then I clicked "next" and it got stuck.
I killed the process and will empty the cache as you recommended, but would really appreciate some more guidance before trying again!
Thank you so much,
Sarah
SteveLynch
After clearing the cache try kriging and if that works then try cokriging
BTW, are the points and the raster in the same coordinate system?
-Steve
SarahSchmeer
Sorry, forgot to mention:  I have run Kriging and it works fine and only take a minute or so.  However, the results are quite unrealistic for this mountainous terrain, so I want to try co-kriging with elevation.  Yes, the point and raster files are in the same coordinate system.
I cannot find the cache of files I'm supposed to delete.  What exactly is the "operating system's temporary file location"?  I looked in the default folder for the Geodatabase, as well as the folder where I actually save everything in my Geodatabase, and I searched my computer for files beginning with ga or ending with .ds and found nothing.
SteveLynch
It'll be a location similar to
C:\Users\xxxxYourNamexxx\AppData\Local\ESRI\Desktop10.0\GeostatisticalAnalyst  (not sure if it is 10.0 or 10 in your case)
If you can't find this then set a Windows System Environment variable called GA_TMP
-Steve
SarahSchmeer
I couldn't find any such folders, nor any such files hiding anywhere.  I think I created a new Windows System Environment, but I have no idea what a System Environment even is, let alone if I did it correctly.  I went to Computer-->Properties-->Environmental Settings-->Create New, called it GA_TMP and "pointed it to a folder" (a very weak description from the ESRI help page); specifically I chose "C:\Program Files (x86)\ArcGIS\Desktop10.0" because that's the closest I could get to the path you gave me in your previous message.
Now when I select my datasets in the GA Wizard I get a box that says "Error" with a red X and no other explanation.
Is there any way to do co-kriging with this silly Wizard?  Seems like there should be a tool for it.
Thanks again for you help--I'm just getting frustrated with the perpetual lack of ArcMap information for non-computer programmers.
SteveLynch
I'm sorry that you are having a problem.
First close ArcMap
Please set the GA_TMP variable to a location like c:\temp
Then open ArcMap again
or reboot your computer or email me at slynch@esri.com
-Steve
SteveLynch
There is a problem with the DEM, it has NoData and �??Not a number�?�. I'm not sure how the NAN values got into the raster.
We�??ll fix the hanging issue that you see in our next release, which will most probably be 10.3.
To fix your issue, do the following:
- RasterToPoint tool
- Then use this feature class in place of the raster
If you really want to use a raster then:
- RasterToPoint
- PointToRaster using the original DEM�??s cell size and extent
-Steve
