Using sensor thing api as an input of Poll an External Website for JSON
1063
06-21-2022 08:45 PM
ShanJuYang
Hi, everyone, I tried to use  Poll an External Website for JSON as my inputs.
And the URL is below
https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things
But it came out an error :  Failed to get a response from...
Is there any way to fix this problem?
I think maybe the problem is  because this url is a  sensor thing api.
JeffSilberberg
I put your link into postman and I get back 1468 lines of json data with no issues.  So you may have some other issue like a BAD DNS lookup or IP / Switch / Firewall security getting in the way -
Here is a part of the retuning objects --
    "@iot.count"77,
    "value": [
            "name""林森",
            "description""臺北市水利處抽水站-林森",
            "properties": {
                "note""",
                "basin""新生大排",
                "manager""抽管一科管理一股",
                "township""中山區",
                "authority""臺北市水利處",
                "createdate""1987-06-01",
                "stationName""林森"
            "@iot.id"1,
            "@iot.selfLink""https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things(1)"
            "name""長春",
            "description""臺北市水利處抽水站-長春",
            "properties": {
                "note""",
                "basin""新生大排",
                "township""中山區",
                "createdate""1979-12-01",
                "stationName""長春"
            "@iot.id"2,
            "@iot.selfLink""https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things(2)"
            "name""民生",
            "description""臺北市水利處抽水站-民生",
            "properties": {
                "note""",
                "basin""新生大排",
                "township""中山區",
                "createdate""1998-03-01",
                "stationName""民生"
            "@iot.id"3,
            "@iot.selfLink""https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things(3)"
            "name""民權",
            "description""臺北市水利處抽水站-民權",
            "properties": {
                "note""",
                "basin""新生大排",
                "township""中山區",
                "createdate""2005-09-01",
                "stationName""民權"
            "@iot.id"4,
            "@iot.selfLink""https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things(4)"
            "name""錦州",
            "description""臺北市水利處抽水站-錦州",
            "properties": {
                "note""",
                "basin""新生大排",
                "township""中山區",
                "createdate""1987-01-01",
                "stationName""錦州"
            "@iot.id"5,
            "@iot.selfLink""https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things(5)"
            "name""圓山",
            "description""臺北市水利處抽水站-圓山",
            "properties": {
                "note""",
                "basin""新生大排",
                "township""中山區",
                "createdate""2000-12-01",
                "stationName""圓山"
            "@iot.id"6,
            "@iot.selfLink""https://sta.ci.taiwan.gov.tw/STA_Pump_Taipei/v1.0/Things(6)"
            "name""濱江",
            "description""臺北市水利處抽水站-濱江",
            "properties": {
                "note""",
                "basin""基隆河",
                "manager""抽管一科管理二股",
                "township""中山區",
                "createdate""1998-05-01",
                "stationName""濱江"
