Poll external website to geoprocessing service
870
03-20-2024 10:06 PM
PierreloupDucroix
Hello,
I am trying to execute a GPserver from Geoevent (the GPserver acts as a gateway to authenticate, then poll an external API and send back the response to Geoevent). The GPServer is published on the Geoevent Server.
However, I noticed that Geoevent cannot automatically pass a token to its own ArcGIS Server in this case (presumably because of the use of "poll an external website" input).
Do you know if there is a solution or workaround for that ?
CEO of MAGIS
RJSunderman
Hello @PierreloupDucroix --
The Poll an ArcGIS Server for Features input uses token authentication, but cannot be configured to use your GP Service. This type of input uses credentials you have entered into a registered server connection to request an authentication token from the ArcGIS Server (or the Enterprise portal) and then uses that token to make authenticated requests. The token returned from the ArcGIS token service gets incorporated into requests the input sends when querying ArcGIS feature services. This is not something you specifically configure; it is inherent in the inbound connector's implementation. This is also our only input that supports paging as it is able to assume the data paging strategy used by ArcGIS Server feature services.
You are correct -- the Poll an External Website for JSON input does not have a mechanism implemented to obtain an authentication token, either from an external web service or (in your case) a GP Service. Even if the "external" server were actually an internal server running ArcGIS Server, this type of inbound connector can only be configured with a URL (and optionally query parameters to pass with the URL) to send single requests to a web service for data. Basically, if you can copy/paste a URL into a web browser, this type of GeoEvent Server input can be configured to make the same query at some specified interval. It cannot query a web service to first acquire an authentication token and then incorporate that token into a second query for data. Nor can it make multiple requests to "page" through a large collection of data records. These sort of multi-step requests for authentication and/or request pagination are not configurable using any out-of-the-box input.
Generally speaking an outbound connector (or "output") is able to make requests on a web service, but is not going to block or wait for any sort of response. That is why we don't have an out-of-the-box output to send requests, for example, to a GP Service. The GP Service should be allowed to run asynchronously and return a job number to the requesting server. As the termination of an event processing workflow, an output is not going to do anything with a job number returned from a GP Service.
A custom processor might be developed to perform a blocking / synchronous operation and make calls to a GP Service, but this is a very bad idea. You should never have a GeoEvent Server element you've configured or developed invoke a GP Service synchronously and allow the HTTP request to block until the GP Service has completed its operation(s). GeoEvent Server was architected to process hundreds to potentially thousands of event records each second. A GeoEvent Service that performs a blocking operation with a GP Service runs orthogonal to GeoEvent Server's design.
The advice is the same if you were considering developing a custom inbound transport invoke a GP Service as part of an authentication workflow. You do not want an input to make requests to a GP Service as a blocking operation as part of data ingestion and adaptation prior to event record processing.
Rather than refer you to blogs on using GeoEvent Server's Java SDK (which is what you would use to develop a custom inbound / outbound transport or adapter -- or a custom processor) I'm going to recommend a different pattern you can follow to obtain authentication via a GP Service.
It is not always possible to send subscription requests to a web service provider so that the web service will periodically push data to your GeoEvent Server. My recommendation for authentication workflows is to handle the authentication externally to GeoEvent Server. Consider developing a "bridge" between the data provider and your GeoEvent Server. The advantage to this approach is that you can develop the "bridge" in any language you are comfortable using -- Python script, PowerShell, ASP.NET, as an Amazon web services Lambda function ... etc.
Your bridge will handle token acquisition and request authentication. The bridge can then query the web service you were thinking to configure a Poll an External Website for JSON input to perform initially. The bridge can obtain the authentication needed to authorize its queries and to pass a token (for example) along with its requests for data. You then develop a way for your bridge to relay the data to  a GeoEvent Server hosted REST endpoint as an HTTP/POST request. This allows you to configure a Receive JSON on a REST Endpoint input to receive the data.
Developing this sort of bridge between a data provider and GeoEvent Server can be very useful. It enables you to send multiple requests to page through large data collections because you can develop the bridge to conform to whatever paging strategy an external web service might use. The bridge can handle  necessary authentication via whatever authorization mechanism is being used. The bridge has an opportunity to "clean" the data before relaying it to GeoEvent Server if, for example, there are characters in attribute field names like '$' that GeoEvent Server does not support. You can also use the bridge to implement a throttling mechanism and relay large amounts of data to GeoEvent Server in reasonable batches of so-many-records-per-second.
-- RJ
