Output Data is not written to Output CSV File
2112
11-04-2023 09:38 AM
MANESK
I'm a newbie to Geoevent Server.
I'm using Input Connector --- Poll an External Website for JSON
Field Reducer --- Processor
Output Connector --- Write to a CSV File
As shown in the attachment, the Geoevent service has begun to read input count and process output count after being started.
The Sample Route shows the sample events in the dialog.
The issue is that the data is not being written to the Output CSV file in the folder.
The folder is shared. Is there anything I'm missing to get the output written to a CSV file?
Also, I tried using the JSON Output connector -- Write to a JSON File
Likewise the output is not written to the Output JSON File..
What is the issue.. Looking for your valuable suggestions.
GaryLSheppardJr
What you've done looks good to me. Have you looked at the GeoEvent Server log messages? You might see clues there.
JeffSilberberg
I would check the underlying server logs.  Bet you do not have the authority to write/create files in the folder you are working with.
MANESK
Changed the folder permissions and restarted the server machine. Worked like charm. Thanks @GaryLSheppardJr  &  @JeffSilberberg  for your suggestions
