Geometry field GEOEVENT SERVER
2231
11-25-2019 05:58 AM
MatteoMei1
Hi everyone, I have a problem: from my csv table containing "x and y" I should be able to get a single geometry field, to then insert the geometry field inside the geodefinition and give coordinates to my Feature output that is on arcgisonline.
how to do? thanks
geoeventser‌
geoevent‌
#helpme
AwesomeEvan
I think this is what you are looking for.
field calc it into a new geometry field then field map it to your geometry field of you final layer, Long_Double and Lat_Double are your field names in this example
'{' + ' "x":' + Long_Double + ',' + ' "y":' + Lat_Double + ',' + ' "spatialReference":{"wkid":4326} }'
Calculate Geometry with GeoEvent
AwesomeEvan
Stefan_Jung
Hi Matteo Mei‌,
it is possible to create a geometry via field calculator. But for a simple Point geometry you could also use the build in functionality "Construct Geometry From Field" (Advanced):
Best,
Stefan
MatteoMei1
thanks to both of you for the help, my problem is that I can't bring the values back into my functionality on arcgis online, how should I build geodefinition? same as the fields on my table? and on building the geoevent after the Field Calculator do I have to use a Tiled Mapper to carry the fields?
clearly my goal is to start from a csv table with the input data and transport them to an empty function on arcgis online or enterprise.
thank you very much
