GeoEventserver Array in GeoEvent Definition
1344
01-28-2025 07:34 AM
Nico9
What should the structure of the new GeoEvent Definition for the JSON data be to read the subsequent JSON data? There is an array in the data, which I cannot get into the GeoEvent definition.
URL to the data stream
https://www.pegelonline.wsv.de/webservices/rest-api/v2/stations.json?waters=POTSDAMER%20HAVEL,POTSDA...
The data is structured as follows:
"uuid": "5e10e1e7-9115-4bd7-ad57-e2062f516891",
"number": "580412",
"shortname": "POTSDAM",
"longname": "POTSDAM",
"km": 26.63,
"agency": "STANDORT BRANDENBURG",
"longitude": 13.072071020002,
"latitude": 52.3998866995299,
"water": {
"shortname": "PHv",
"longname": "POTSDAMER HAVEL"
"timeseries": [
"shortname": "W",
"longname": "WASSERSTAND ROHDATEN",
"unit": "cm",
"equidistance": 15,
"currentMeasurement": {
"timestamp": "2025-01-28T15:15:00+01:00",
"value": 102,
"stateMnwMhw": "normal",
"stateNswHsw": "unknown"
"gaugeZero": {
"unit": "m. ü. NHN",
"value": 28.434,
"validFrom": "2019-11-01"
"shortname": "WT",
"longname": "WASSERTEMPERATUR ROHDATEN",
"unit": "°C",
"equidistance": 60,
"timestamp": "2025-01-28T15:00:00+01:00",
"value": 4
"shortname": "LT",
"longname": "LUFTTEMPERATUR ROHDATEN",
"unit": "°C",
"equidistance": 15,
"value": 7.6
The output from the input processor currently looks like this:
"GED_Name": "potsdam_input",
"number": "580412",
"km": 26.63,
"longitude": 13.072071020001967,
"water": "water : PHv,POTSDAMER HAVEL",
"timeseries": "[timeseries : W,WASSERSTAND ROHDATEN,cm,15.0,currentMeasurement : 2025-01-28T15:15:00,102.0,normal,unknown,gaugeZero : m. ü. NHN,28.434,2019-11-01, timeseries : WT,WASSERTEMPERATUR ROHDATEN,°C,60.0,currentMeasurement : 2025-01-28T15:00:00,4.0,null,null,null, timeseries : LT,LUFTTEMPERATUR ROHDATEN,°C,15.0,currentMeasurement : 2025-01-28T15:15:00,7.4,null,null,null]"
If I feed this into a fieldmapper, I get this output:
"GED_Name": "potsdam_output",
"number": "580412",
"km": 26.63,
"water_shortname": "PHv",
"water_longname": "POTSDAMER HAVEL",
"timeseries_shortname": "null",
"timesseries_longname": "null",
"timeseries_unit": "null",
"timeseries_equidistance": "null"
I can process the data stream fine up to the array "timeseries", but I can't get the array to work. Can someone help me define the input or output GeoEvent definition for the array?
Thanks
Nico
TimoT
Hi @Nico9
Hopefully someone more knowledgeable can chime in as it has been a while since I've used Geoevent Server.
You can use field mapper to flatten the data structure. Use dot notation for nested fields, and index notation for arrays.
Refer to the following resources for more information and examples:
TimoT
Hi @Nico9
Nico9
Hello TimoT,
this a
https://community.esri.com/t5/arcgis-geoevent-server-blog/json-data-structures-working-with-hierarch...
In the Output GeoEvent definition, you can access the contents of the array by specifying the index.
In my case, this works like this, for example:
timeseries[0].unit
Thanks for the help!
