Geoevent Feature Layer (hosted) has no data from the stream
1133
03-29-2025 09:33 AM
ggregor_pulsiam
I have an issue with creating a stream with Geoevent.
It creates 3 files when I create the output service:
Feature Layer
Map Image Layer
Feature Layer(hosted) when opening in the portal the data tab, it says at the bottom "There was an error."
The stream is working in the Feature Layer and I see all the data correctly, but I would like to see the stream data in my hosted Feature layer, so I can create a View Layer for example.
Is there a way to do this, or some settings that I missed.
Thank you for the help in advance.
JeffSilberberg
So, can you be more explicit as to what the error is?
Also, have you looked at this Knowledge Entry?
https://support.esri.com/en-us/knowledge-base/faq-what-are-the-options-to-share-a-hosted-feature-lay...
ggregor_pulsiam
That's all it says at the bottom There was an error when I open the Feature Layer(hosted) that was created in GeoEvent, but like I said it create a Feature Layer where I see all the data and a Map Image Layer.
JeffSilberberg
Sorry,
    You are going to have to open a support ticket.
