Field Mapper REST [ ]
580
09-19-2024 02:55 AM
Nico9
I would like to process fields from a REST API in the Field Mapper. That works so far. Unfortunately, some data in REST is configured strangely and I cannot process it in the Field Mapper.
REST URL: https://www.pegelonline.wsv.de/webservices/rest-api/v2/stations.json?includeTimeseries=true&includeC...
So far I know how the following REST code has to be specified in the field mapper:
"water": {
"shortname": "ALLER",
"longname": "ALLER"
Field Mapper
water.shortname
water.longname
My problem is the nesting with [ ]:
"timeseries": [
"shortname": "W",
"longname": "WASSERSTAND RAHDATEN",
"unit": "cm",
"equidistance": 15,
"currentMeasurement": {
"timestamp": "2024-09-19T11:30:00+02:00",
"value": 259.0,
"stateMnwMhw": "normal",
"stateNswHsw": "unknown"
"gaugeZero": {
"unit": "m. ü. NN",
"value": 8.0,
"validFrom": "1985-03-13"
For example, I tried this for the shortname:
timeseries.shortname
and for value:
timeseries.currentMeasurement.value
Both lead to "NULL" values
How do the [ ] have to be taken into account in the field mapper?
Thanks for your advice!
JeffSilberberg
Am I reading this correctly, you have array's with the json ?
Just use the appropriate Arcade function to process the array.
https://developers.arcgis.com/arcade/function-reference/array_functions/
https://community.esri.com/t5/developers-questions/parse-data-from-json-in-arcade/td-p/557738
