ERROR while "mvn clean install"
6087
11-20-2019 02:17 AM
MinxueChen
I'm trying to follow the Geoevent Developer Guide to run the samples. But meet a problem while trying to run the "mvn clean install" with sample "sample-adapter":
Is it because of maven version stated in the pom.xml is too old? (The maven I installed is version 3.6.2, the eclipse version is 4.13, the m2e version is the latest 1.13).
Has anyone meet the same problem and maybe have a suggestion?
Thank you so much for your help!
Stefan_Jung
Hi Minxue Chen‌,
looks like maven is trying to access the central repository: https://repo.maven.apache.org/maven2
Do you have an internet connection on the machine you are building on?
I've just tested the sample from 10.7.1 with Maven 3.6.1 and everything worked fine. But Maven downloaded a lot of artifacts from the central repository.
Best,
Stefan
Stefan_Jung
Hi Minxue Chen‌,
Best,
Stefan
MinxueChen
Hi Stefan,
Thank you! Yes, after switching a different network, I was able to build it. It's definitely an internet issue.
Bests,
Tony
