Coordinate System in GEP
851
01-07-2014 06:14 PM
aymansalah
If my input data contains WGS84 coordinate system, and I want my output geometry to be in different Coordinate System. How I can achieve this
RyanElliott
Ayman,
There are currently no built-in processors that project the geometry.  That leaves two options.
  • If you output the data to a Feature Service, your client application can specify the desired coordinate system when querying the feature service for features.
  • If you need to project the geometry in the geoevent service, then you will need to create a custom processor using the SDK.
-Ryan
