Errors "Unable to start blueprint container for bundle" in GeoEvent Processor startup
3734
01-08-2014 12:08 AM
by Anonymous User
Not applicable
Original User: LuisARG_Esri
I've installed GeoEvent Processor in a server and it worked until yesterday. Today when I've started GeoEvent Processor, several "Unable to start blueprint container for bundle" errors happen and GeoEvent Processor doesn't work properly, neither the GeoEvent Processor Manager nor Service Designer work.
I attach the log file.
KenMiller
Check out this other forum by clicking on the URL below.
http://forums.arcgis.com/threads/91097-GeoEvent-Processor-errors
by Anonymous User
Not applicable
Original User: javidel
Luis,
Judging by your log file, it seems like corruption in one of your geoevent definition files is causing the problem.  Unfortunately, this occasionally happens if GEP exits unexpectedly or is force-killed.
At this point, I'd recommend renaming the directory C:\ProgramData\ESRI\GeoEventProcessor\geoeventdefinitions to something like C:\ProgramData\ESRI\GeoEventProcessor\geoeventdefinitions.original and restarting GEP.  That should get you up and running again, although you will have to recreate any GeoEvent Definitions you authored manually after a restart.
Let us know if this gets you up and running again.
-Javier
LuisRodríguez_González
Hello, your solution works.
Thank you very much.
Regards
Luis
