Add Field Splitter Processors as part of the standard installation
806
12-14-2023 10:35 AM
Status: Already Offered
GIS_Spellblade
The ability to split incoming data based on groups or geotags seems a fairly standard process-- --especially if you are trying to populate downstream applications with the ability to filter based on a single attribute. Since much of the data streams are outside of a user's control, these processors are invaluable to split up data into a way that is usable within the downstream apps (experience builder, dashboards, etc.) which are not well-designed to ingest multi-categorical data.
Since this tool is already Esri supported, let's add it into the standard installation and allow users to utilize it without the need to install the GeoEvent SDK.
https://www.arcgis.com/home/item.html?id=68238a93e5fd4043ad0bbb501b265566
https://github.com/Esri/field-splitter-for-geoevent
https://github.com/Esri/multi-cardinal-field-splitter-for-geoevent
1 Comment
GregoryChristakos
If you're running GeoEvent Server 11.1+, you can deploy the Field Splitter Processor from GeoEvent Manager without the need to do anything with the GeoEvent SDK.
See: https://enterprise.arcgis.com/en/geoevent/latest/reference/use-the-add-on-manager.htm#:~:text=To%20o....
Simply search for the Field Splitter Processor in the Gallery add on manager (within GeoEvent Manager) and deploy it via "install". Installed add-ons will persist on upgrade of GeoEvent Server. You can even obtain updated versions of this processor outside the normal release cycle using the add on manager (assuming there are updates available).
