Almost There--I Think...
1590
02-16-2022 11:14 AM
JorgeKappa
What needs to be done for the models and surfaces to show on the scene?
Tags (1)
by Anonymous User
Not applicable
Hi @JorgeKappa,
It looks like you have the GeoBIM connection working now. Are you wanting to learn about how to create GIS features from your stored BIM content, and then publish that to a scene in the web browser that can be used in GeoBIM? If so, this learn path includes that overall idea on the different steps https://learn.arcgis.com/en/paths/gis-and-bim-learning-path/ and the areas you are probably wanting to learn more about will be on using your Revit content as layers from these resources:
  1. https://www.esri.com/arcgis-blog/products/arcgis-pro/3d-gis/geolocating-revit-files-in-arcgis-pro/
  2. https://www.esri.com/arcgis-blog/products/arcgis-pro/3d-gis/make-sense-of-your-bim-data-by-leveragin...
  3. https://www.esri.com/arcgis-blog/products/arcgis-pro/aec/autodesk-civil-3d-surface-as-ground-in-arcg...
by Anonymous User
Not applicable
Hi @JorgeKappa,
RebekaAlvarez-Heck
