Did you add Global ID's to your featureclasses before creating the mobile cache as it is said in here ?
"For mobile services, the type of data repository used can potentially affect how you can use the data in the field. If your data comes from a file geodatabase, after you host it on ArcGIS Server, the data becomes read-only even though you have added a GlobalID to it. If your data is from an ArcSDE database and you do not register the data to the server before publishing, your data becomes read-only as well. However, these restrictions do not apply to feature services, that is, data is still editable even it has no GlobalID or stored in a file geodatabase."
Hope this help
