How do I make an operational layer editable?
4440
05-12-2015 01:35 PM
GaryHallbauer
I've tried everything I can think of on the file geodatabase and ArcGIS Desktop side. Whenever I run the mobile cache tool and import it into Mobile Project Center the feature class shows up as 'read only' and the field properties can't be changed.
JérémiePedoia
Did you add Global ID's to your featureclasses before creating the mobile cache as it is said in here  ?
"For mobile services, the type of data repository used can potentially affect how you can use the data in the field. If your data comes from a file geodatabase, after you host it on ArcGIS Server, the data becomes read-only even though you have added a GlobalID to it. If your data is from an ArcSDE database and you do not register the data to the server before publishing, your data becomes read-only as well. However, these restrictions do not apply to feature services, that is, data is still editable even it has no GlobalID or stored in a file geodatabase."
Hope this help
