Unknown error collecting features
2689
01-02-2014 11:46 PM
KerstinServatius
I use ArcGIS for Windows Mobile 10.1.5001.3320 on an Spectra Precision Mobile Mapper 10.
When I try to collect features (points) I get the message that an unknown error occured while saving features. If I cancel the feature collection and go to the manage changes section (I have the german language version, don't know if this is the right translation) the program closes with an exceptional error. The Logfile says the following:
Message:
InvalidOperationException
Stack Trace:
bei ESRI.ArcGIS.Mobile.FeatureCaching.FeatureDataReader.InitCursor()
bei ESRI.ArcGIS.Mobile.FeatureCaching.FeatureDataReader.Reset()
bei ESRI.ArcGIS.Mobile.FeatureCaching.FeatureDataReader..ctor(FeatureSource featureSource, QueryFilter queryFilter, EditState requestedEditState, Boolean lockedRead, String[] columnNames)
bei ESRI.ArcGIS.Mobile.FeatureCaching.FeatureDataReader..ctor(FeatureSource featureSource, QueryFilter queryFilter, EditState requestedEditState, String[] columnNames)
bei ESRI.ArcGIS.Mobile.Client.FeatureSourceInfo.GetFeatures(QueryFilter queryFilter, EditState editState)
bei ESRI.ArcGIS.Mobile.Client.FeatureSourceInfo.GetFeatures(EditState editState)
bei ESRI.ArcGIS.Mobile.Client.Tasks.Synchronization.UpdatesListPage.OnLoad(EventArgs e)
bei System.Windows.Forms.Form._SetVisibleNotify(Boolean fVis)
bei System.Windows.Forms.Control.set_Visible(Boolean value)
bei ESRI.ArcGIS.Mobile.Client.Page.ESRI.ArcGIS.Mobile.Client.IPage.Show()
bei ESRI.ArcGIS.Mobile.Client.MobileApplication.Transition(IPage nextPage)
bei ESRI.ArcGIS.Mobile.Client.MobileApplication.Transition(IPage2 nextPage, Boolean disposeWhenDismissed)
bei ESRI.ArcGIS.Mobile.Client.Tasks.ManageEdits.ManageEditsTask.Execute()
bei ESRI.ArcGIS.Mobile.Client.Pages.SelectTaskPage.ListViewItemActivated(Object sender, EventArgs e)
bei ESRI.ArcGIS.Mobile.Client.Controls.ExtendedListView.OnItemActivated(EventArgs e)
bei ESRI.ArcGIS.Mobile.Client.Controls.ExtendedListView.OnMouseUp(MouseEventArgs e)
bei System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
bei System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
bei Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
bei System.Windows.Forms.Application.Run(Form fm)
bei ESRI.ArcGIS.Mobile.Client.MobileApplication.Main(String[] args)
bei ESRI.ArcGIS.Mobile.Client.Program.Main(String[] args)
I have no idea what could be the reason and I would be very thankful if anybody could give me a hint on how to get the feature collection to work.
Kerstin
