Problem with label in ArcPAD 10
804
07-02-2012 12:34 PM
GustavoBediaga
I am having a problem with labelling in ArcPAD 10. In my ArcMap 10 MXD I set up the "Define classes of features and label each class differently" method that excludes one class for showing up its label ("no name" class) in a layer. It works fine in ArcMap, and no feature in the "no name" class is labeled. Then I use the "Get data for ArcPAD" tool. When I open the APM result map, the class feature that does not show its label in the MXD shows its label in the APM map.
Can anyone help to set the label correctly in my project?
Gustavo Bediaga
IBAMA/Brazil
