Mobile Cache and Mosaic dataset??
2060
01-18-2011 05:37 AM
RobertMEIER
I have an mxd with a mosaic dataset in it, that is all that is in it. I want to make a Mobile Cache from this. In the Create Mobile Map tool, when I load the mxd path, the exents and layers list are not populated as normal. I set the output folder and click ok, but then I get error messages in the results window. Attached is a screen shot of the error.
Are mosaic datasets not compatible with Mobile Caches??
Any help is appreciated.
DeniseKing
Hi Robert,
The Create Mobile Map tool does support both vector and raster layers from the input map document (.mxd). The output folder must exist prior to running the Create Mobile Map tool yet it doesn't appear populated in your screenshot. Please test if this resolves the error.
Cheers,
Denise
