invalid client checksum
3381
05-19-2010 01:14 AM
RomboutVerwimp
We have a client application build on top of the ArcGIS server mobile ADF.   We have difficulties to get the map synchronisation stable.  We continuously get a "invalid client checksum" in the logs of our ArcGIS server, so the sync process itself is not taking place...  According to the ESRI documentation this is due to a change on the database schema or the mxd-schema but we know that neither the mxd, neither the database schema has been modified since the publishment of the mobile service
Does anyone had a similar problem?  Any suggestions for a solution? We would like to understand better what is being evaluated in the initial startup of the synchronisation.
Thx!
MaximilianGlas
we had similar problems for a long time. The main problem was not to know, when checksum was changing.
Then we got informations, on what the checksum is depending and when it changes:
Map
  • Full extent of the map (Xmin, Ymin, Xmax, Ymax)
  • Units
  • Spatial reference
  • Number of workspaces
  • Layer count
Layer
  • Layer type
  • Layer index
  • Workspace index
  • Is versioned or not
  • Extent (removed in 9.3.1)
RasterLayer
  • Raster width
  • Raster height
FeatureLayer
  • Feature class schema
  • Field count
  • Field name
  • Alias field name
  • Field length
  • Field flag (type, editable, null}
  • Subtype code
In our case the problem was a changing map extent which was redefined automatically because new features were outside the old defined extent.
Hope this helps.
Greets, Max
Jitendrudulacaraju
I am getting the same error.
But from the developer machine it works and from the deployment machine it fails.
Any clues?
Jitendrudulacaraju
I have got over with this problem. Simply changed the extent of the MXD by making the a smaller scale  map and restarting the service. Temp fix, but is it permanent?? Have to see.
