Featurelayer InScaleRange not working anymore
833
04-27-2011 09:10 AM
Wolf
by Esri Regular Contributor
I ported some 9.3 Mobile code to 10.0 and found that the following code sequence is not working anymore:
private Map m_theMap = ...;
FeatureLayer featLyr = ...
MapLayer lyrFeat = clsMapUtil.FindMapLayer(featLyr.Name, m_theMap);
if (featLyr.InScaleRange (m_theMap.Scale)) ...
featLyr.InScaleRange used to return true for the following value:
the values are as follows:
lyrFeat.MinScale = 10063.854373775863
lyrFeat.MaxScale = 0.0
m_theMap.Scale = 9086.4508347532319
Any ideas on this problem?
StephenDickinson
My experience mirrors your own.
Have you tried manually calculating whether the layer is within the scale range?
e.g.
            MapLayer associatedMapLayer = map.MapLayers[associatedFeatureLayer.Name];
            //InScaleRange method doesn't seem to work, MapLayer.MinScale and MapLayer.MaxScale
            //values seem to be wrong way around, so calculate our own
            bool inScaleRange = (map.Scale <= associatedMapLayer.MinScale) && (map.Scale >= associatedMapLayer.MaxScale);
            //if (associatedMapLayer.Visible /*&& associatedMapLayer.InScaleRange(map.Scale)*/)
            if (associatedMapLayer.Visible && inScaleRange)
Wolf
Stephen,
I implemented that code as a work around and this seems to work.
