Eclipse Error Message on Running HelloWorld ArcGIS for Android Application
3058
08-08-2011 04:29 PM
MichaelLiu1
Hello,
I have followed the instruction to create my first HelloWorld ArcGIS for Android application.  After I set up the AVD and proceed to Run As Android Application, Eclipse Console brings up the following error messages:
[2011-08-08 15:27:21 - Emulator] invalid command-line parameter: and.
[2011-08-08 15:27:21 - Emulator] Hint: use '@foo' to launch a virtual device named 'foo'.
Please advise how to resolve this issue.  Thanks in advance.
Regards,
PeterrIISAGER
The error does not seem to relate to the ArcGIS for android application but rather the AVD setup.
Try to check here: http://stackoverflow.com/questions/6603194/starting-the-android-emulator-in-sdk-tools-revision-12
MichaelLiu1
Appreciate the clarification. The famous Issue 18317... Gracias!
