Error in posting updates.
3444
03-18-2011 05:28 AM
IndraBisen
I'm using ArcGIS Mobile 10. When I'm trying to post some updates in one layer which is polygon type, I got following error -
Post Update Errors- Could not establish protocol with the service. Please contact your administrator.
I'd tested with some polygon which I'd created manually and it works. But after creating some more polygons by the code and trying to post the updates I got this error.
The polygons created by the code are displaying properly on the map and the Manage Edits shows <no. of newly created features> Features created..
I had also exported the mobile cache to shape file and shape file is perfect.
regards
Indra Bisen
AlexProtyagov
Does your feature layer, the table, has GlobalID column? If not you can create it via ArcCatalog.
FabianHeredia
I am creating the mxd directly to gdb and this generated the cache. when I try to synchronize get an error: Error posting updates for "name feature" layer.
Hang_KwaiPun
Hi Indra_Bisen, Is it possible there is something wrong with the service itself? Can you restart your service or host the map as another mobile service?
