Container Process Crashed when Synching Data
1827
01-31-2011 06:28 AM
ApurvaGoyal
I am trying to sync data from mobile application using the sync agents. However everytime I sync I get an error with message-"The remote server returned an error-(500)Internal Server Error. Looking at the ArcGIS Server logs I found the error "Container process xxxx crashed on machine xxx" being logged.
The features that I am trying to sync are contained in a network feature dataset.
Is this error being thrown because the feature dataset on server is a network dataset? Any help on this is appreciated.
Thanks
Apurv
ChristopherOlsen
Is this only happening with the Network dataset, or have you tried making simple updates to other data in the project and syncing those changes?
Are you using 9.3.1 or 10 mobile?
ApurvaGoyal
Yes this is happening only with Network dataset. I have been able to push updates to other simple datasets just fine. I am using ArcGIS Mobile 10.
Thanks
Apurv
ChristopherOlsen
It looks like they are not supported at this time:
http://help.arcgis.com/en/arcgismobile/10.0/help/index.html#//007v00000008000000.htm
"Network analysis layers are dynamic, and results are stored in memory. They are not supported."
ChristopherOlsen
This may also be a good one to look up or post on the Ideas site-
http://ideas.arcgis.com/ideaList?c=09a300000004xET&category=ArcGIS+Mobile&sort=top
ApurvaGoyal
Thanks Chris.
