ArcGIS for Windows Mobile Create Cache with Token not working
2495
03-30-2016 08:17 AM
by Anonymous User
Not applicable
I am using ArcGIS for Windows mobile.  I can successfully create a mobile cache if the service is not secured.  However if I add security or try to use a token it fails on the CreateCache with a nullReferenceException.  Any ideas are appreciated!
             //@"http://<YourServer>/<YourArcGISServerInstance>/rest/services/<YourMobileServiceName>/MapServer/MobileServer";
                MobileServiceConnection mobileServiceConnection = new MobileServiceConnection();
                mobileServiceConnection.Url = mobileServiceUrl;
//if the line below is commented out this works flawlessly.  If I add this line on the CreateCache line below it will fail
                mobileServiceConnection.TokenCredential = new ESRI.ArcGIS.Mobile.CatalogServices.TokenCredential("MyUserName", "MyPassWord");
//these next 2 lines are just an alternate that I tried
//mobileServiceConnection.TokenCredential.UserName = "MyUserName";
  //              mobileServiceConnection.TokenCredential.Password = "MyPassWord";
                mobileCache1 = new MobileCache(cacheStoragePath);
                if (mobileCache1.CacheExists == true)
                    mobileCache1.DeleteCache();
                if (mobileServiceConnection.IsValid)
                    MobileCacheTextBox.Text = "isValid";
                else
                    MobileCacheTextBox.Text = "Not Valid";
          //the line below is where it returns a nullReferenceException when the Token is being set
                mobileServiceConnection.CreateCache(mobileCache1);
                mobileCache1.Open();
                return true;
