Troubleshooting Configuration?
2537
11-09-2012 03:57 AM
KirkHolbrook
I am re-installing ESRI Maps for IBM Cognos 4.2 on our development server (in conjunction with Cognos 10.1.1) after we had some changes in our internal infrastructure.
I seem to have the components installed correctly, but am apparantly not getting the configuration correct.
The ISAPI redirect is not working for the Admin JSP page:
Requested URL http://ourservername:80/cognos/jakarta/isapi_redirect.dll
Physical Path D:\cognos\c10_gateway_x32\webcontent\jakarta\isapi_redirect.dll
I am using the 64bit version of the ESRI Maps component, but have 32 bit Cognos Gateway. The only mention of which bit-version to use in the documentation seems to imply OS bit-version rather than Cognos bit-version, but perhaps that is an issue?
Any thoughts are greatly appreciated.
BTW the documentation is pretty good, but very slim on installation/configuration troubleshooting.
Kirk
Tags (3)
JacobSummers
Kirk,
Excellent Question.  Configuring the web server was tricky on Vantage 4.2.  We have simplified this procedure for Vantage 4.3.
Here are a couple points for configuring the Vantage ISAPI redirect for Vantage 4.2:
- On a 64 bit machine, the 64 bit ISAPI should be used.  It is located in 'vantage/gateway/isapi/isapi_redirect_x64'.
- The 64 bit ISAPI redirect must run in a 64 bit only app pool.  To achieve this:
   a) Create a new app pool
   b) Move the jakarta application to the new app pool
   c) Set the property 'Enable 32-Bit Applications' to false (under Advanced Settings).
Have a great week,
Jake
