remove esri logo
3711
07-06-2011 02:37 PM
ChrisBradberry
Hey,
Does anybody know if you can remove the esri logo at the bottom right corner of the map?
Chris
RahulMetangale
Hi Chris,
Try MapApplication.Current.Map.IsLogoVisible=false;
ChrisBradberry
Rahul,
Where do you put that code?  I tried putting it in a text editor web part, but it did not work.
Chris
AlagiriVenkatachal
Hi Chris,
To do this, you could create a Map behavior by extending the Map Web Part as discussed in the below doc:
http://help.arcgis.com/en/webapps/sharepoint/help/WritingMapBehaviors.html
and illustrated in the Interactive SDK sample:
http://sharepoint.arcgis.com/SitePages/Disable%20Map%20Animation.aspx
Upon attaching the Behavior, you would have to make a call to "Map.IsLogoVisible = false"; this should make the logo not visible. You would get access to the Map through the AssociatedObject (shown in the above doc also).
-Alagiri
RahulMetangale
Hi Chris,
Attached is sample behavior to hide ESRI logo based on Alagiri's instructions.  Please follow the steps from following url to configure the behavior:
http://help.arcgis.com/en/webapps/sharepoint/help/ConfiguringExtensions.html
-Rahul
