Refreshing the map
4173
05-31-2013 12:13 PM
PerryClark
Greetings:
My Esri Maps for MS Office map refreshes and the symbols changes as expected when I enter new values by manually typing them into the table.
I have created a macro that populates my maps source table with "values only" harvested from various non-GIS friendly sources in the Excel file.  The Esri Maps for MS Office map does not refresh or display new values when I change the values in the table using my macro.
I am seeking ideas for programmatically or manually refreshing the map after bulk copying new data to the maps source table?
Perry
PerryClark
It would nicer if the Esri application had a refresh data button, but here is a workaround:
'Copy cells one by one to force the Esri Maps for MS Office map to update
Dim FirstCell As Range
Dim FirstTargetCell As Range
Dim i As Integer
Set FirstCell = Sheets("SourceSheet").Range("BG11")
Set FirstTargetCell = Sheets("GISReadySheet").Range("BG2")
i = 0
Do
FirstTargetCell.Offset(i, 0).Value = FirstCell.Offset(i, 0).Value
i = i + 1
Loop Until FirstCell.Offset(i, 0).Value = ""
End Sub
EricBowman
Hi Perry,
I would suggest you place this code into an idea on the Ideas site - ideas.arcgis.com.  That way it goes straight to the developers and others that work with the products.
Hope this helps.
Regards,
Eric
AndrewHargreaves
This works well to refresh the map within Excel, but is there a way to programatically 'update the shared layer'?
PerryClark
gg7aph
I am not sure exactly what you are asking, but if you are talking about pushing data from Excel into a feature data using ESRI Maps for MS Office, I think that is beyond the design of the application.
There are numerous discussions about pushing data from Excel to a SDE feature class.
Perry
