Issues with connecting ArcGIS for Sharepoint map with another web part. No interaction!
1631
04-05-2024 04:31 AM
ElvisHerrera
I'm new to ArcGIS for sharepoint. I've been trying to look for tutorial videos on this plug-in, but there's not many out there.
I created a sharepoint list with coordinates (I activated the location column). On my web page, I created an ArcGIS for Sharepoint map using that sharepoint list. I created another web part (using the list option) and add my sharepoint list. From there, the instructions I found were to go to map edit and initiate the "connect web part." I used my sharepoint list are the web part source and I selected the column I wanted.
Here is where nothing happens. I did not get any errors when I establish the connection, but when I go to click on a row in my sharepoint list web part, nothing happens. When I click on a point in my map, nothing happens. Not sure what I'm doing wrong. Am I not supposed to use the same sharepoint list for my map web part and my list web part?
RaajRaaj
@ElvisHerrera - Thanks for reaching out to us.
Per your comment, I believe you have followed the steps correctly to establish the connection between the map web part and the list web part. After setting up the connection, you can use the "Validate" button to see if there are any matching features/records. Even otherwise, if there are no matching features/records, you should still see a toast message displayed at the bottom right corner of the map. The toast message will indicate if there are matching records or "no matching records".
I am sharing some links from Esri ArcGIS blogs and also the blogs from Esri Community.
You can enable notifications in Esri Community (ArcGIS for SharePoint Community) so that you get notified whenever we post new blogs.
I have also shared the link to a blog which explains the web part connectivity between the ArcGIS for SharePoint app and custom apps that can be built on the client-side to interact with the map web part. With custom or 3rd party apps, you can establish a two-way communication between your custom web part and the ArcGIS web part.
We are here to help, so, feel free to reach out to us if you are still experiencing any issues while setting up the web part connectivity or if you have any questions related to the ArcGIS for SharePoint app.
Esri ArcGIS Blog explaining the list to ArcGIS web part connectivity - https://www.esri.com/arcgis-blog/products/esri-maps-sharepoint/mapping/dynamic-mapping-with-sharepoi...
Please refer to the " ArcGIS web part as a Consumer” section - https://community.esri.com/t5/arcgis-for-sharepoint-blog/using-dynamic-data-extensibility-feature-to...
ArcGIS for SharePoint blog site - https://community.esri.com/t5/arcgis-for-sharepoint-blog/bg-p/arcgis-for-sharepoint-blog
Thanks & Regards,
Raaj
