How do you create layers
2830
03-01-2014 12:53 PM
MurrayBlack
I am trialling Esri Maps for Office and have created a map from an excel  table using filtering to select certain records. But I would like to show another set of data on the same map but with a different colour. I can't find anything in 'help' or the tutorials. I suspect I need to create a new layer. Can anyone point me in the right direction please.
by Anonymous User
Not applicable
If you make a selection and then click the Add Excel Data, it will use that selection. You can do the same multiple times and then change the symbol for the layer by selecting "Style" from the menu or the right click context menu. Another option is to add all the data to the map and then use the "Grouping" option to create a map of sized symbols based on Number ranges or categories.
