Esri Maps for Sharepoint 4.0: How to configure Guest Login
4305
08-11-2015 02:52 AM
ThomasBohnert2
we've installed Esri Maps for Sharepoint 4.0 and meanwhile we're able to set the App Configuration Settings correctly.
Now I'm able to enable guest access as well. I've done that, provided a Guest Login and set the option "Start session with guest signed in by default".
If I load the page, I get the following selection
First question is: Why?
Wit h the option "guest signed in by default", mentioned above, I would have expected to sign in directly.
The second question is:
When I choose "or CONTINUE AS GUEST" then nothing happens. There's only a refresh of the page and the same selection appears again and again.
Any help would be appreciated.
Thanks!
MaryEllen_Perko
Hi.  We are experiencing the same behavior so thought I'd see if anyone learned anything they can share.
Thanks.
ThomasMontefusco
There were issues in 4.0 Is it possible to upgrade to 4.1?
