Error ESRI Map for office windows 7
4608
01-10-2014 12:16 PM
CésarGarrido_Lecca
Hi, I have installed the latest version of esri maps for OFICCE Inglés v. 2.1.2.
But when trying to enter my credentials online arcgis button for logging is not active.
Windows 7
Office Proffesional Plus 2010
The internet is perfect, no problems of proxi and also can login Agol account  in Arcmap.
Please i need Help
SusanJones
I have had similar issues the last few months with ESRI Maps for Office.
It seems as if Microsoft Office (Excel) is not able to resolve the Proxy Dialogue credentials.
Accessing the same services from Portal from the same machine will work.
See My earlier forum post.
Susan
IyanSandri
Susan, the link to your earlier post is not working and I am running into a similar issue. Can you post the link again, or copy the information.
thank you
I
SusanJones
I lost the link to this as well.
But go into ArcGIS Administrator -> Advanced -> Manage Portal Connections
Make sure the portal and agol entries are there.
Test the connections.
If that still fails
Goto Control Panel -> Internet Options ->Advanced - Security
Uncheck
Check for publisher's server revocation
Check for server certificate revocation
