Can you Filter in the Esri Maps Web Part 3.0.1?
1306
01-08-2014 05:57 AM
MikeGregotski
I've got some data (ArcGIS Server feature services) that I have been using in the older ArcGIS Web Map Part.  The data has been filtered using the Filter tool in the Layer menu.  This works great since I can filter my services based on attributes.
I'm now creating a new page with the Esri Maps Web Part and I want to fitler these same ArcGIS feature services.  The problem is that it doesn't look like filtering is available for the new Esri Maps Web Part.
Can anyone comment on if this Filter functionality is available in the Esri Maps Web Part or if there are plans on adding it in a future release?
Thank you,
Mike
MikeGregotski
I heard from Esri that this isn't currently possible in the Esri Maps Web Part.  It is something that may be included in the future.
As a workaround, I could group the data and then turn off the groups I don't want to see.  This could work a bit like filtering but for now I'll stick with the ArcGIS Web Map Part for when filtering is needed.
