ArcGIS Web Part for SharePoint - Bookmark tool
1322
08-23-2013 12:01 PM
chaitragopalakrishna1
Hello team,
Can we use ArcGIS Silverlight Bookmark tool xap file and add that to extension library and use in ArcGIS Web Part. I tried this but I don't get option to configure the bookmarks.
Thanks
Thanks Katy. I am able to configure bookmark tool by following your steps. Thank you
KatherineDalton
Hi Chaitra,Technically you can bring the Bookmarks tool from the Silverlight Viewer to SharePoint and use it in the Silverlight-based ArcGIS Map Web Part, but the implementation isn't quite the same. You have to configure the Bookmarks when you're configuring the tool, and the dialog for adding the Bookmarks is modal (in SharePoint), so you have to navigate to the location, click Configure, add the bookmark, and then close the dialog again to get back to the map to navigate to the next location. Hope that helps,Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
