ArcGIS Web Part accessing IHS Energy Map Service
2744
08-27-2013 10:19 AM
chaitragopalakrishna1
Hello Team,
I am trying to access map services provided IHS. I created Proxy file as mentioned in the help "http://resources.arcgis.com/en/help/sharepoint/concepts/0159/01590000007m000000.htm". If I browse the proxy file, it is working as expected by providing secure token. But if I try to add map server to the web part I get error message "No Map services were found at the mapserver". If I manually store the token in client session and try to browse the mapserver url in the web part without enabling "Add Secured Services" it works fine. I used Proxy.zip file mentioned in the help file to create proxy web application. Should I use SharePoint proxy file. The url to this file is broken in the help file.
Please let me if anyone has solution for the problem mentioned above
