413 RequestEntityTooLarge - Automating EXIF metadata extraction workflow
584
01-28-2026 02:59 AM
CID
Hello,
We have enabled the flow "Automating the EXIF metadata extraction workflow" in a Sharepoint library to extract EXIF data, but when it runs on files larger than 10 MB, the following error appears: “413 - RequestEntityTooLarge.”
Is there any way to solve this issue?
Thanks in advance
RaajRaaj
@CID
Thanks for reaching out to us via Esri Community.
Would you be able to share a sample file in a private message?
Also, have you tried using the "client-side" solution without the Power Automate flow and does that work fine?
Thanks & Regards,
Raaj
CID
Hello
Private message sent.
Using the option "Extract Exif data" without the Power Automate flow, it works fine.
Thanks & Regards
