Now getting message This map does not meet the requirements for embedded reports after working
987
09-10-2025 11:21 AM
NancyMilholland1
I created a Power BI report that contains several maps. This was published and initially was embedded successfully. This has stopped working - the maps have successfully passed all the checks with me logged in as a user. The maps work within Sharepoint as well. However when I access the link created for embedding a map, I get the message "This map does not meet the requirements for embedded reports " The location well is blank as the maps use x and y coordinates. Data is not coming from ArcGIS for the map and no additional ArcGIS services are added to the map.
I've attached an example of the map in powerBI showing the ArcGIS visualization frame and the successful checks.
JV_
I'm facing the same problem. Have you found a solution?
