Since update the feature information will not toggle on whether you use power bi desktop or power bi online. I sign in and use a public facing service or map and once I try and toggle on feature information it removes everything.
Hi Roxanne, Thanks for reporting this. Are you seeing this behavior immediately upon toggling the setting, or does it happen after selecting a specific layer or field?
To help us troubleshoot, could you share a few quick details?
ArcGIS for Power BI Version: (You can check this in the visual's settings/about menu)
Power BI Environment: Does this happen identically in Power BI Desktop and the Power Service (web), or is it isolated to one?
Layer Type: Is this happening with standard AGOL feature layers or Power BI data layer?
