Giving edit functionality for ArcGIS within a PowerPage
843
11-14-2023 06:46 PM
MikeGrady
I have a use case where a designer wants to connect two points on a map to map-out things like flow lines, roads, etc. Then they'd like to be able to extract the distances and use that as a quantity to feed into an estimate.
The overall solution is a custom developed PowerApp, so we were keen to understand whether we can embed ArcGIS within a PowerPage to support this high-level design work.
Can you confirm if this is covered by updates to a feature layer or whether this is something that is anticipated to be developed in terms of funcationality?
