Welcome to the New ArcGIS for AutoCAD Group
3990
17
08-22-2014 02:41 PM
DonKuehne
This is the start of the ArcGIS for AutoCAD Group.
MatthewFallau
Is it possible to attach a drawing or zipped folder here?  If not is there an email where it can be sent?
DonKuehne
dkuehne@esri.com should work.
DonKuehne
I seemed to work fine for me (at least what you sent me).  I am thinking perhaps the feature service capabilities you are working with didn't have the curves turned on?  (worth a check).
Here are the features (zoomed in) from my server...
MatthewFallau
Does object data within the original CAD entities have any affect on feature services?  Some of the CAD entities within the local feature classes that were utilized contain MAP3D object data.  I'm curious if this would create the Error in  QueryFeatureData?  From my understanding ARCGIS FOR AUTOCAD reads xrecords and not objectdata tables.
DonKuehne
No, the object data would/should have no effect.  I suspect it has something to do with the geometry.  I am seeing the same thing with the expanded data set you sent.   Looking into why...
KarlWilson
Hi Matthew,
The reason you are not seeing all your features in AutoCAD is because when the "QueryFeatureData" error occurs it stops the synchronization process dead in its tracks. You only get the features that have loaded up to that point.
You may find this thread useful:
�??Error in QueryFeatureData�?� ,
Regarding geometry, I have had many issues with true curves, especially ellipses. You may find this thread useful:
https://community.esri.com/message/58702#58702
I'm still struggling with both issues today.
Karl
RobertMEIER
I am new to using this, I am trying to use feature services and edit in AutoCAD. Some layers work fine, others give this error "Errors encountered in adding extracted features to drawing". I have public test services that you can look at -
http://prdgis.bartwest.com/arcgis/services
Use the services in the Testing folder.
Thanks!
Robert Meier
DonKuehne
Thanks for providing the test service, that is extremely helpful.  looking into it...
