Contour Lines with Elevations
2930
04-05-2016 11:20 AM
DMFACER
Is there a way to insert contour lines through ArcGIS for AutoCAD from a feature service that are assigned elevations in the AutoCAD properties?  Is there something I have to do on the service side when it's published, or something I need to do when connecting to the service in AutoCAD in the plugin?  Any help would be appreciated.
KarenHodge
Hi Matthew.  Currently, if the source feature service is 2d, and the feature service includes a field called "Elevation", then ArcGIS for AutoCAD will draw the feature at the specified Z value.
However, if the field is called "Elev", or "Contour", it is just a property, and won't impact the Z values.
Hope this helps!
--Karen Hodge, ESRI
